logo
What makes using Group Policy so challenging?
Group Policy is powerful but challenging to use because of the sheer number of settings administrators must manage. While common policies like password enforcement are familiar, many obscure options are hard to find without reference tools. Since most administrators juggle multiple responsibilities and rarely use Group Policy daily, expertise is difficult to maintain, making navigation and recall of settings a time-consuming task.
Group Policy management is a powerful way to enforce security and standardize settings across your IT environment. But with thousands of available configurations, it can be difficult to quickly locate the exact setting you need. To simplify the process, Microsoft provides the Group Policy Search Tool, which helps administrators find the right setting without wasting valuable time.
Without a resource like this, many pointed out that when it comes to using Group Policy, one of the most time-consuming and challenging tasks is simply recalling or locating what setting is needed for the particular task. Group Policy management allows you to control just about every user or machine behavior in your environment. The list of things you can manage with GPO settings is long and likely the primary reason why it’s so difficult to use it effectively unless you work with it every day.
Most administrators out there juggle multiple responsibilities and know how difficult it can be to acquire a high level of skill in a technology especially one that isn’t used often. Group Policy management can fall into this category. Many GPO settings for objects and behaviors such as enforcing a password policy and setting default desktop backgrounds are familiar and easily found and understood. Lesser known GPO settings are more like mythical creatures. You’ve heard a setting exists yet you can’t say for certain you’ve seen it let alone use it.
If you need more control over what’s going on in your environment and want to implement change auditing for Group Policy management and GPO settings, take a look at Netwrix Auditor for Active Directory. It audits all changes in Group Policy and automatically sends detailed e-mail reports showing who made what changes, when and where as well as before and after information. Furthermore, it can store this data for seven years or more and can generate custom reports.
I hope you visit the links above and get a chance to check out this great free tool to help your Group Policy management tasks. What is your most strange, mythical, mystical or odd Group Policy setting you worked with and how did you use it? Share your stories below and let me know if you found this tool useful too:
As General Manager, Adam is responsible for product lifecycle and market adoption from concept to implementation through to customer success. He is passionate about market strategies, and developing long-term path for success for our customers and partners. Previously, Adam served as CMO and has held a variety of senior leadership positions at Stealthbits - now part of Netwrix including Sales, Marketing, Product Management, and Operational Management roles where his focus has consistently been setting product strategy, defining roadmap, driving strategic engagements and product evangelism. Adam holds a Bachelor of Science degree in Business Administration from Susquehanna University, Selinsgrove, PA.
