logo
Top 10 Group Policy PowerShell Commands
In addition to the Group Policy Management Console (GPMC), Microsoft provides a set of Windows PowerShell cmdlets you can use to manage Group Policy. To use the Group Policy PowerShell cmdlets, you must have GPMC installed on the device where you will run the cmdlets. To check if the Group Policy PowerShell module is installed on a device, run the command below, which will display all the available Group Policy cmdlets available if the module is installed.
Get-Command -Module GroupPolicy
Creating a New Group Policy Object
Let’s start by creating a new Group Policy object (GPO). The command below creates a new GPO called ‘Netwrix PCs’ and adds a comment to describe its purpose:
New-GPO -Name "Netwrix PCs" -Comment "Client settings for Netwrix PCs"
 The command creates an empty GPO with no settings. If you have starter GPOs configured in your Active Directory domain, you can create a new GPO based on their settings. The following command creates a new GPO called ‘Netwrix PCs’ based on the ‘Windows 10 MS Security Settings’ GPO:
New-GPO -Name "Netwrix PCs" -StarterGPOName "Windows 10 MS Security Settings"
 You can optionally link the GPO to a domain, domain controller’s organizational unit (OU) or site using piping. The command below creates a new GPO and links it to the Clients OU in the ad.contoso.com domain:
New-GPO -Name "Netwrix PCs" | New-GPLink -Target "ou=clients,dc=ad,dc=contoso,dc=com"
 To unlink a GPO, use the Remove-GPLink cmdlet:
Remove-GPLink -Name "Netwrix PCs" -Target "ou=clients,dc=ad,dc=contoso,dc=com"
Group Policy PowerShell Commands How to Link and Unlink a GPO
Figure 1. How to link and unlink a GPO
Getting Information about a GPO
Once a GPO is created, you can use Get-GPO to return information like GPO status, creation time and last modification time:
Get-GPO -Name "Netwrix PCs"
 If you want more information, pipe the object created by Get-GPO to Get-GPOReport. The script below creates an HTML report that gives information about the GPO similar to what you might see in the Group Policy Management Console:
Get-GPO -Name "Netwrix PCs" | Get-GPOReport -ReportType HTML -Path c:tempreport.html
Group Policy PowerShell Commands HTML Report with Detailed Data about a Specific GPO
Figure 2. HTML report with detailed data about a specific GPO
Configuring Group Policy Settings
If you know the location for a registry-based Group Policy setting, you can use the Set-GPRegistryValue cmdlet to configure it. Registry-based Group Policy settings are those that appear under Administrative Templates in GPMC. Set-GPRegistryValue can also be used to set registry values that are not covered by Group Policy settings. For example, if you want to configure registry settings for third-party applications that don’t have an ADMX file for Group Policy, Set-GPRegistryValue is a quick way to configure the settings you need. The following command sets a screensaver timeout of 300 seconds for the logged-in user:
Set-GPRegistryValue -Name "Netwrix PCs" -Key "HKCUSoftwarePoliciesMicrosoftWindowsControl PanelDesktop" -ValueName ScreenSaveTimeOut -Type DWord -Value 300
 You can specify either computer configuration or user configuration settings using Set- GPRegistryValue The registry path in the -Key parameter below starts with “HKCU” (which stands for “HKEY_CURRENT_USER”). If you want to configure a computer setting instead, replace “HKCU” with “HKLM” (which expands to HKEY_LOCAL_MACHINE).
To get detailed information about a registry key configured in a GPO, use Get-GPRegistryValue:
Get-GPRegistryValue -Name "Netwrix PCs" -Key "HKCUSoftwarePoliciesMicrosoftWindowsControl PanelDesktop"
Group Policy PowerShell Commands How to Get Detailed Information about a Registry Key Configured in a GPO
Figure 3. How to get detailed information about a registry key configured in a GPO
To remove a registry setting from a GPO, use Remove-GPRegistryValue:
Remove-GPRegistryValue -Name "Netwrix PCs" -Key "HKCUSoftwarePoliciesMicrosoftWindowsControl PanelDesktop" -ValueName ScreenSaveTimeOut
The three cmdlets above have Group Policy Preference equivalents if you decide to use Preferences instead of Policies to set registry keys: Set-GPPrefRegistryValue, Get-GPPrefRegistryValue, and Remove-GPPrefRegistryValue.
Applying Group Policy Settings
Provided that your GPO is linked to a domain, OU or site, it will apply to user and computer objects below where it is linked. But if you want to force a Group Policy update on a remote server or other device, you can use Invoke-GPUpdate. Running Invoke-GPUpdate without any parameters will force an update of user and computer configuration settings on the local computer. The command below forces a Group Policy update on server1 for user configuration settings only:
Invoke-GPUpdate -Computer "adserver1" -Target "User"
Reviewing which GPOs Are Applied to a User or Computer
To get information about which GPOs are applied to a user or computer, you can generate a Resultant Set of Policy (RSoP) report using the Get-GPResultantSetOfPolicy cmdlet. The command below generates a report for the computer called “dc1” and writes the results to the c:temp directory:
Get-GPResultantSetOfPolicy -Computer dc1 -ReportType HTML -Path c:tempdc1rsop.html
Group Policy PowerShell Commands How to Get Information About Which GPOs Are Applied to a User or Computer
Figure 4. How to get information about which GPOs are applied to a user or computer
PowerShell cmdlets can be quite useful for managing Group Policy. However, configuring settings inside GPOs using PowerShell isn’t easy because Group Policy settings weren’t designed with text-based configuration in mind.
IT consultant and author specializing in management and security technologies. Russell has more than 15 years of experience in IT, he has written a book on Windows security, and he coauthored a text for Microsoft’s Official Academic Course (MOAC) series.
